How to register
How to register
If resets buttons are greyed , it means the software is not correctly registered .
how to register :
1 - Ensure that the software can establish a connection with the bike.
If the sofware cannot pull informations , it may means the cable you are using are not well configurated and not suitable for your bike.
The process registration cannot work without pulling data from the bike.
2 - Once the data are pulled on the software , press get licence button ( the blue one ).
your computer shall be connected to internet, it will open the registration page .
If your computer is not connected to internet , after pressing the get liccence button , the registration link will be paste in your clipboard.
simply get connected to internet and paste the registration link in your browser to follow the registration process
3- Complete the form to receive the licence.
- the email where to send the licence file
- the bike details ex : monter 1200s 2018
- no others data shall be entered , do not alter the prefilled part
you will receive a cle.lic file quickly
4 - Install the cle.lic file into your application forlder ( melcodiag or jpdiag)
do not paste a shortcut , neither rename the file . Fhe name shall be cle.lic . cle(1).lic wont works.
5 - Restart the application connected to the bike , the reset buttons shall be enabled.
What to do if this is still not working :
- ensure cle.lic is present and not renamed .
- if you put the application in a a directory not beloging to your home folder , windows will restrict the file permissions .
you will have to access cle.lic properties and tick unlock file.
- in case you having a bike not poping the SN , genallry MTS2010 to 2012 , ensure to register the app with the PC you will use for the diag , else that wont works
recent example of not right registration:
bike : DUC4630800 => i don't know this model
serial : 7F9FCë => should be between 9 and 10
bike : 5291xt => i don't know this bike
bike : multistrada 1200- scrambler 800- monster- hipermotard- v4 => WTF ???
Kyrayan
Re: How to register
Post by Kyrayan »
Hello. I connected ms4 with kkl409 and jpdiag. I copied it and wanted to send it to you to get a license, but I received a notification that it is not necessary and 59m can work without a license. Is it true?
Re: How to register
what is an MS4 ?
it's right that 59m ecu don't need to register
prusso
Re: How to register
Post by prusso »
Hi @jp250rs. A few days ago I tried registering and the form said the request was sent successfully or something along these lines, but I never got the license sent over. I tried regitering again, maybe I did something wrong the first time, but git an error message saying something like the vin/email combination were already registered. Can you help me out?
I'm trying to read the some error codes to understand what is the DSS error that keeps popping up in my dash, but maybe I need to be registered to read those?
Here is the data from the debug file in case it helps:
"File generated On 15/07/2026 05:51:21"
"Software version 2.0.5.1"
"Auto Detect Bike = MTS1200S"
"User Bike = Multistrada 1200s GranTurismo 2013"
"Ecu = DNPBT000318"
"Softw = 00000304"
9 PIDS active founds
022_0000000000000000
018_00005E0000000004
024_BF888FBE00000000
020_0500004878020000
080_04000400000000C8
240_E170E000002AA400
300_C609840102C60940
230_0000000000080000
190_3800787C00FFFC5C
*ECU found TX:7E0 RX:7E8
*ECU found TX:7E1 RX:7E9
"Vin = ZDMA300AADB003133"
"08B64B4A"
PaniVIN:
MultiVIN:
M3dVin:
DashVin2:
DashVin:
EcuVin:
? outp='ZDMA300AADB003133'
PaniVIN: ZDMA300AADB003133
? outp='DNPBT000318'
? outp='J001'
Re: How to register
yes you successfully register the 1st time , then you got an email with the key inside
check you spam it's prolly there
when you tried to register again , it said , ecu is already registered . nothing wrong to me
prusso
Re: How to register
Post by prusso »
Oh, crap, you're absolutelly right. It was in my spam box indeed, sorry for not checking it properly before. Thank you very much for the app and support.
On a side note, I saw sometime ago you started working on a mobile version of the app. Not sure the reasons behind not going forward with it, but if you want to give it another go and need some help, please let me know, I would love to support this as a side project. I have about 20 years of client-side development (mostly web, last 4 years on mobile, some CLI and desktop as well). Let me know! Cheers!
Re: How to register
i'm on many project in the same time , i'm also working on an autonomous obd device .
i didn't finish the mobile app , cause i have not found suitable and affordable device for IOS
so i made my own interface . but that's bringing an other issue , to finish it and mass produce it
