Hello
After running through the setup I was able to connect the software, then download a licence but could not proceed further so went for a break.
Since re connecting after a break and re visit of the steps to ensure I’ve done things correctly I couldnt get Melcodiag to connect to my Ducati MTS 1200 (2011) and it displayed a com error. After changing usb ports this solved it.
However, I have the licence saved with the melcodiag files but it’s not greyed out and was prompted to send a debug report, which is below before I can proceed please?
Thanks for the help. Donation will follow once sorted as very impressed.
"File generated On 14/02/2026 15:06:45"
"Software version 2.0.1.5"
"User Bike = MTS 1200 (2011)"
"Ecu = MELCO HIMEJI "
"Hardw = J001"
"Softw = 00000007"
4 PIDS active founds
080_06000000C8000006
020_0000005528F00000
018_00001E0010001D14
"B7A11C33"
"Bike = 6"
0 : 031a8f03
1 : NO DATA
2 :
3 : >
0 : A9021A8f
1 : F1037F1A11000000
2 :
3 : >
0 : 021a90
1 : 037F1A31
2 :
3 : >
0 : 031A8FD0
1 : NO DATA
2 :
3 : >
0 :
1 : >031A8FD0
2 : 037F1A31
3 :
4 : >
** MTS BBS DATA **
A9021081
NO DATA
A903214505
NO DATA
A903214800
NO DATA
A903214401
NO DATA
A903214501
NO DATA
A903214400
NO DATA
A903214500
NO DATA
A903214402
NO DATA
A903214502
NO DATA
A903214404
NO DATA
A903214504
NO DATA
A903214403
NO DATA
A903214000
NO DATA
A903214100
NO DATA
A903214200
NO DATA
A903214300
NO DATA
Have licence but can’t proceed further
Re: Have licence but can’t proceed further
you are usinga very old version , i invit you to re download melcodiag
your licence file is not valid , if you changed the PC since the last attempt , you need to register again
Milo1g2838
Thanks for responding.
What is the latest version please? I used the DVD, (yes, very 90’s) which came with the cable from EBay
Milo1g2838
Ok so I downloaded from the site and re registered (got another licence), dropped in the Melcodiag directory restarted the pc and still the licence button isn’t greyed out.
Report below. Thanks.
"File generated On 15/02/2026 11:14:49"
"Hardw = J001"
"Softw = 00000007"
" vin DATA
vin 037F1A11
vin 7F1A31
vin 31A8FD07F1A31
300_4506041A5AF0B000
230_0000000000000000
080_08000000C8000006
110_8032580440000E00
"B7A11C33"
"Bike = 6"
"Hardw = J001"
"Softw = 00000007"
" vin DATA
vin 037F1A11
vin 7F1A31
vin 31A8FD07F1A31
"B7A11C33"
"Bike = 6"
i see you use different PC
be sure you use same PC for register and melcodiag
Milo1g2838
I downloaded a fresh (latest version) of Melcodiag and licence onto the new pc. The first laptop stopped working/it was old so I had to try a new device.
I’m unsure what steps to take? Should I delete all files on the new device then re install and request a new licence?
you should register from the pc you will use with melcodiag.
do not transfer the lic to an other PC that won't works
if you still have problems , do the checks in the step 5 here viewtopic.php?t=5
Milo1g2838
Those steps helped and identified the licence file was locked.
All sorted.
Thank you.
All sorted.
Thank you.
