Activate heated grips for hypermotard/hyperstrada 821
matou
Post by matou »
I successfully connected to my by hyperstrada 821 over a bluetooth adapter. It would have been great to be able able to activate the heated grips. I have just installed some but I believe that I need to go to the dealer to have them first activated in the ECU. I was hoping that Melcodiag could do this but clicking on the button "grip heat ON" on the "active tests" tab mad the adapter blink, but nothing happens after that. I disconnected, switch the bike Off and On again but unftortunately the feature is not activated.
This is my report from Mecodiag, maybe someone sees something or has a trick to activate them?
"File generated On 16.02.2026 15:58:18"
"Auto Detect Bike = Hyper 821"
"User Bike = hyperstrada 821 2014"
"Softw = 12"
" vin 145A8F035A444D4232303041414542303037393932
8 PIDS active founds
020_03000E03D6003700
120_840B010000000402
024_A657972600000000
080_00108430000000C8
018_0000420000000003
230_00000000000
"Vin = ZDMB200AAEB007992"
"322907FF"
ZDMB200AAEB007992
Re: Activate heated grips for hypermotard/hyperstrada 821
you shall see the elm blinking when you enable grip right ?
have you tried to click grip off ? ( in case i crossed the command)
matou
Post by matou »
thanks for the reply!
Yes, the ELM blinked multiple times. I only tried multiple times the "ON".
Will try the "Off" and report again.
matou
Post by matou »
no, unfortunately, the "off" command does not work neither.
I tried multiple series:
Off only, did not work
clicked back on ON, but did not work.
Moved back to Off, still does not work.
matou
Post by matou »
Latest version of Melcodiag enabled my heated grips on my '14 hyperstrada 821!
Well done!
Merci infiniment!
(Cable Lonelec bluetooth with ELM 1.5)
