Hi All,
I have a 2010 Multistrada 1200s that I'm trying to reset the Desmo service warning on.
i have had no problems hooking up the bike and Melcodiag software is able to connect and communicate with the bike (I'm able to poll different settings etc). However, when I press either the Service or Desmo reset buttons, the app hangs and does nothing. Subsequent button pushes get the spinny wheel and "app not responding' from windows.
I have this connector https://www.ebay.co.uk/itm/204528012749 which I'm assured works with Ducatis though I note it's showing as Elm V1.5 on the Melcodiag software.
Does anyone have any solutions please? I have searched but couldn't find anything specifc.
Thanks!
Ken
2010 Multistrada - Connects, communicates, won't reset
firebladeboy1993
Re: 2010 Multistrada - Connects, communicates, won't reset
you can press service button instead .
and if it's still not working , choose the 2nd model date option , and try the 2 reset buttons again
firebladeboy1993
Hi JP,
Thanks for the reply.
Yes, tried that, with the same result.
In fact, most of the buttons seem to result in a lockup of the app after pressing, even ones that work, like the Speedo and Rev counter tests.
Any further advice?
Ken
Any further advice?
Ken
keep insisting , this is the way it works with your bike
there is no VIN in the interface right ?
firebladeboy1993
Yes, no VIN retrieved so I get to select 2011 or 2012 (my bikes a 2010) Tried both options with the same result.
Testing various options, most (but not all) of the passive tests work OK but the Active tests, even if they work, trigger the app to hang.
Here's the dump data:
"File generated On 3/9/2026 8:37:37 PM"
"User Bike = MTS 1200S / 2010"
"Ecu = 090359798"
"Hardw = J001"
"Softw = 00000007"
" vin DATA
vin 037F1A11
vin 7F1A31
vin 31A8FD07F1A31
080_06000000C8000006
020_0000005528A00000
018_000042001000C65C
100_400718377B34DD00
150_00A3A3487C8103FF
160_C8C8838383830400
210_0000000000000000
"5E891501"
"Bike = 6"
Looks prettty generic - not sure if there's anything there that will help?
Thanks!
Ken
"Ecu = 090359798"
"Hardw = J001"
"Softw = 00000007"
" vin DATA
vin 037F1A11
vin 7F1A31
vin 31A8FD07F1A31
"5E891501"
"Bike = 6"
Thanks!
Ken
thanks for the report it confirm the licence is active ,and you have a 2010 or 2011 bike
yes when there is no vin app hangs , i'll fix that , but you shall be able to choose a different year and press service and desmo button
firebladeboy1993
Ah, OK, So you think, even though the App hung, it's reset the service/desmo data? The Desmo service display was showing -100 but it only shows periodically, so it's possible it's been reset. I'll go for a ride when it stops raining to find out
Thanks for the help and for providing the tool. It'll be great as it develops further and the loose-ends are tied up!
Ken
Ken
