2022 Desert Sled Euro 5
cfcDave16
Post by cfcDave16 »
Hi would the software work for my Desert Sled 2022 Euro 5 - Annual Service Reset - thanks
Re: 2022 Desert Sled Euro 5
service reset yes , but annual i'mnot sure
viewtopic.php?t=45
cfcDave16
Post by cfcDave16 »
Hi thanks for the response - I bought 2 x ELM OBD 2 cables one has a switch and the other doesn't both are version v1.5
downloaded software from your site - attempted to connect firstly with ignition off but both have CAN BUS ERROR displayed
Then i turned ignition on and reconnected - no messages regarding CAN BUS ERROR but no other details are displayed
filled in details for bike and year and selected create report - report saved to main folder -
when i attempted to get licence an error came up on web page saying unable to send as some information is missing
Is there a user guide available - which gives step by step instructions
my com ports are set up correctly and the software connects but i cant seem to populate any bike info on the software
i have attempted all of the above with both OBD 2 Cables but the results are the same for both
any help or advice appreciated - have copied the debug text file below if it helps
"File generated On 06/04/2026 11:59:02"
"User Bike = scrambler desert sled 2022 euro 5"
" vin:NO DATA>
188_7FEB801F80CF4CE7
022_000000000003FC3D
18C_8003800200000DE4
023_000000547F130CC7
024_0000000000260E6C
150_00001092000042FA
020_0040001000000897
02A_0001800000000887
080_2BC2BC1F00200E7C
100_C802000FFF001D01
174_E67F0050466B04D1
178_0E800243816904E3
17C_048001007C81041A
"46EC8E36"
cfcDave16
Post by cfcDave16 »
Hi have managed to reset annual service due -
tried different scenarios but was only able to get licence by selecting "any bike" to create report and forward to get licence
Once licence received - opened software and connected again by using "any bike "
Turned ignition on - connected - waited for ECU to sync and populate bike info - reset tab - annual service 0 and annual service 1 selected in turn and eventually cleared on display - took a couple of tries - thanks
Donated for you -
thanks ;)
so we can consider annual reset is working too , i'll had it to the success
