Multistrada 1200s 2013
Re: Multistrada 1200s 2013
Thank you very much, I'll check it out. I also think my exhaust flap is stuck. But thank you very much.
**I found and fixed the problem. The cause was a seized exhaust valve.**
**During the inspection, I removed the valve cable, and after switching the ignition on, I read a servo motor fault with MelcoDiag. The fault was successfully cleared. The diagnostics are working correctly: faults can be read and cleared successfully.**
**Thank you very much for your help.**
