I've requested a license file for my Monster 937 2024 and already received it, many thanks
I've copied it in main folder of Melcodiag but when i run it (laptop already connected to bike via obd and dashboard on) and i click connect, the "Get License" button is still present and I'm unable to reset service interval, only vehicle number and other data are present but I can't do anything on Resets
I'm using Melcodiag version 2.0.4.9
Thank you for your help
Melcodiag "Get License" still present
Re: Melcodiag "Get License" still present
have you made the verification after 5 here ? viewtopic.php?t=5
Hello, thank you for reply
I confirm that: cle.lic file is named correctly, folder that contains app and license file is on desktop (there are also 2 more files, 1 named EnDtcM.dll and the other named Msdll.dll), I've tryed both untick and tick unlock file in cle.lic properties and also tryed to run Melcodiag app as admin. Also restart pc
Get license button still present and I'm still unable to reset service light. The connection is ok because I can read vehicle number and I tryed to read service date and I can successfully read it
Waiting for kind answer, thank you so much for help
have you try to launch melcodiag with admin rights ?
what language your system pc is running ?
Yes, I already try with admin rights
Pc language is Italian
i check you registration , you can do it agaon cause it was not correct , and licence as well
Yes!!! New license works! Thank you so much mate, you're amazing. No more service light. Many thanks!
