2024 Ducati Scrambler EDU Identification Issues
cyclingdude723
Aloha,
I have recently acquired a 2024 scrambler that I was hoping to use this SW with. Here is the report output. I was able to successfully connect to the ECU but it does not find the VIN or other information on the ECU. This bike has a 6 pin ECU connector.
"File generated On 6/8/2026 2:58:30 PM"
"Software version 2.0.5.0"
"User Bike = Scrambler /2024"
" vin:NO DATA>
100_00020560000004F3
023_000000547F7F085B
188_800B7C4B80A348F8
18C_7FF780017FE30847
174_E17F00000A6B0E56
178_0E80040569950EA4
17C_0000000065850EDD
020_0040310000000EB9
018_0002A00020D04E76
019_9609600000000E75
024_0000000020000553
080_228306C02000052C
084_4AF271000000054F
"0A5B16FE"
" vin:NO DATA>
"0A5B16FE"
Re: 2024 Ducati Scrambler EDU Identification Issues
have you tried choosing anybike ?
cyclingdude723
Yes I have. Both methods successfully connects to the ECU but I get a NULL in the ECU type, Bike, SW, and VIN areas.
your elm is coming from where ?
v1.5 need to comes from serious shops else they are not working
cyclingdude723
Its a cheap chineseium ELM adapter: https://www.amazon.com/dp/B0C13M3W78.
Last edited by cyclingdude723 on Thu Jun 11, 2026 9:59 pm, edited 1 time in total.
have you tried the 2 speeds ?
cyclingdude723
Aloha,
To eliminate the V1.5 variable, i purchased a V1.4 adapter but unfortunately I am still having the same issues. Here is the log. I have tried both 'Any bike' and 'M3C/D' options. I have also tried hitting "Yes" and "No" on the 2011 / 2012 question that pops up in the options that come up on the "Any bike" option.
"File generated On 6/15/2026 10:26:30 AM"
"User Bike = 2024 Scrambler"
"Hardw = N/A"
"Softw = N/A"
022_000000000003F7F2
023_000000547FEF079D
188_80137C33803F4730
18C_800380017FF70759
024_0000000020000DBB
080_22030AC020000DA6
084_4B12690000000DBB
100_0002012000004D34
174_E77F0000ED6A0CE9
178_F87F012252950C24
17C_000000009C850CEC
020_0040311000000AE8
018_0002A00020D04A02
019_9609600000000A01
"0A5B16FE"
"Bike = 7"
PaniVIN:
MultiVIN:
M3dVin:
DashVin2:
DashVin:
EcuVin:
PaniVIN:
MultiVIN:
M3dVin:
DashVin2:
DashVin:
EcuVin:
PaniVIN:
MultiVIN:
M3dVin:
DashVin2:
DashVin:
EcuVin:
"Hardw = N/A"
"Softw = N/A"
"0A5B16FE"
"Bike = 7"
PaniVIN:
MultiVIN:
M3dVin:
DashVin2:
DashVin:
EcuVin:
PaniVIN:
MultiVIN:
M3dVin:
DashVin2:
DashVin:
EcuVin:
PaniVIN:
MultiVIN:
M3dVin:
DashVin2:
DashVin:
EcuVin:
any chances there is 2 ports and you are plugged on the wrong one ?
cyclingdude723
There is only the single 6 pin port.
can i remote your pc now ?
