Aloha,
I have recently acquired a 2024 scrambler that I was hoping to use this SW with. Here is the report output. I was able to successfully connect to the ECU but it does not find the VIN or other information on the ECU. This bike has a 6 pin ECU connector.
"File generated On 6/8/2026 2:58:30 PM"
"Software version 2.0.5.0"
"User Bike = Scrambler /2024"
" vin:NO DATA>
100_00020560000004F3
022_000000000003F849
023_000000547F7F085B
188_800B7C4B80A348F8
18C_7FF780017FE30847
174_E17F00000A6B0E56
178_0E80040569950EA4
17C_0000000065850EDD
020_0040310000000EB9
018_0002A00020D04E76
019_9609600000000E75
024_0000000020000553
080_228306C02000052C
084_4AF271000000054F
"0A5B16FE"
2024 Ducati Scrambler EDU Identification Issues
cyclingdude723
Re: 2024 Ducati Scrambler EDU Identification Issues
have you tried choosing anybike ?
cyclingdude723
Yes I have. Both methods successfully connects to the ECU but I get a NULL in the ECU type, Bike, SW, and VIN areas.
your elm is coming from where ?
v1.5 need to comes from serious shops else they are not working
cyclingdude723
Its a cheap chineseium ELM adapter: https://www.amazon.com/dp/B0C13M3W78.
Last edited by cyclingdude723 on Thu Jun 11, 2026 9:59 pm, edited 1 time in total.
have you tried the 2 speeds ?
