Hypermotard 950 SP 2021 - desmo service can't be reset
Hypermotard950sp
Post by Hypermotard950sp »
Hello everybody,
I try to reset the desmo service of my hypermotard 950 SP 2021, but I can't manage to do it.
Annual service and oil change service are fine ( reset works as expected), but demso is not working. Also, when I click on the button, I don't see any light blinking on the elm.
Is it a known issue ?
Thank you
Re: Hypermotard 950 SP 2021 - desmo service can't be reset
unfortunatly i have no feed back about desmo
you'r the 1st
do you know the ecu manufacturer ?
silthi
Post by silthi »
Qui c’est , peut être que si tu rajoutes 10ans à la date il te demandera le service desmo.
La méthodologie
Tu change la date
Tu coupe la moto 30sec
Tu réinitialise le service
Tu rallume et remet la bonne date .
Hypermotard950sp
jpl250rs wrote: Sat Jul 18, 2026 8:57 am unfortunatly i have no feed back about desmo
you'r the 1st
It is a continental M4C
can you post the report ?
Hypermotard950sp
I managed to do the desmo reset finally, but I don't know which thing solve my issue, because I have done these 2 things at the same time :
- Change the date to 2036, power down for 30s, then do the desmo reset (heard the sound validation from windows).
- Update MelcoDiag from 2.0.4.4 to 2.0.5.2
Thank you to both of you.
great!
