STREETFIGHTER V4S no license
lenik929
Post by lenik929 »
Hello. I can't send a request to the license. Can you tell me what the error is?
"File generated On 24.07.2026 11:25:23"
"Auto Detect Bike = Streetfighter V4S"
"User Bike = 2022"
"Hardw = """
" vin 145A8F035A444D3146303041414D42303030333238
080_1E322602252008A1
100_C81200000000076C
020_0043930000004818
174_E47F0063DB8307C8
178_FA7F0930836507F1
17C_F87F0100D18E07F0
018_0002A00081084997
019_96096000000309F2
024_00000000000009FF
188_80037DD7804F487B
18C_80037FFF000009FE
023_000000547FB3080F
330_40805915899104E8
"Vin = ZDM1F00AAMB000328"
"1AD85969"
ZDM1F00AAMB000328
Re: STREETFIGHTER V4S no license
you can try the new melcodiag version 2.0.5.1.
and make a report again if you still have the issue
lenik929
Post by lenik929 »
Good afternoon! Thank you for sending the license promptly. The program has been activated. Service intervals have been reset. However, data on the condition of the motorcycle (transmission, RPM, mileage, etc.) is not reflected correctly. The DQS error could not be counted. when errors are requested, the program turns off and turns on the ignition, and the error disappears and is not reflected in the error list when it appears again.
https://disk.yandex.ru/d/t6B8E7HzcHvg6g
the live data on the 1st pas are not yet added for your electronics
for the dtc i don't quite understand what you mean
lenik929
Post by lenik929 »
n the DTC tab, when trying to read the error code, the program turns off and turns on the ignition of the motorcycle. At this point, the error codes disappear. I tried to take a video.https://disk.yandex.ru/i/DbW8fdiS9fTYVw
You shall not start the engine when you want to check errors or reset . It shall be ignition on engine off
lenik929
Post by lenik929 »
When the "Scan DTC" button is pressed, the program initializes the engine block itself. This happens in 1 sec. No action is taken on my part after pressing the "Scan DTC" button.
Ok I will improve this part
