I am using MelcoDiag V2.0.4.4 and ELM327 V1.5
MelcoDiag reads the vin correctly but sees the bike a 2022 Dial 1260S as Xdiavel S2019, I assume that would be OK
However no matter has many times I have tried I can not reset the Annual Service last done by dealer on October 2023.
And dash indicator shows Oil Service -9306Mi Demo Service -17556Mi and Annual Service 24/10/06
Any ideas?
I would assume since they system reads the vin number correctly then the connection is OK
Melcodiag will not reset Annual Service 2022 Diavel 1260S
Re: Melcodiag will not reset Annual Service 2022 Diavel 1260S
can you post the debug report then i can see if the software version and the elm is ok ?
thanks
thanks
Thank you, here it is:
I tried again, and the service light is still on
"File generated On 2/24/2025 3:52:36 PM"
"Auto Detect Bike = Xdiavel S 2019"
"User Bike = 2022 Diaveel 1260S"
"Hardw = """
" vin 145A8F035A444D4741485257314E42303035333534
019_9609600000030754
174_E67F004EA8690074
178_00800132866B005C
020_0000551000000B4E
17C_F47F01009F7C000B
024_0000000000000BC5
080_1B12BCC010200BD3
100_0012040040000B88
188_7FE77DE7801742EA
022_000000000003F29B
023_000000007FC30209
018_0002A000420048FC
"Vin = ZDMGAHRW1NB005354"
"60818025"
ZDMGAHRW1NB005354
***reset date interval***
service date : 250224
"Hardw = """
"60818025"
ZDMGAHRW1NB005354
setup / cables / registration all ok
we can try to change the bike type and give it an other try .
i'll send you instructions
OK Thank you very much.
Did changing the bike type get it working?jpl250rs wrote: Tue Feb 25, 2025 6:24 pm setup / cables / registration all ok
If so maybe the same fix will work for my issue (2020 Diavel 1260 showing as 2019)?
I have a 2020 Ducati Diavel 1260
