Only pulls VIN - Licence Button does nothing
JohnDeere01
Re: Only pulls VIN - Licence Button does nothing
I think I finally made it work correctly !!! and have requested a licence....
JohnDeere01
Thank you so much - sorted !
Hello there, can you tell me what you did to fix the problem? I'm having the same problem. i did get the license but buttons are not working
have you seen the end of this post ?
viewtopic.php?t=5
viewtopic.php?t=5
Okay now it works. I was on “any bike” it worked on “m3c,m3d…” i went ahead and cleared my check engine light. Now the neutral light is blinking and the gear indicator says C and its also blinking. Any idea why?
seems you reset the gear sensor ,
now you shall re learn all gear following the procedure
