Hi! I have Full termi on my hypermotard 950, the oficial dealer installed the exhaust and their racing evo map, with the ducati dqs computer (original ducati for this exhaust).
I have no upmap, my question is... if i reset the oil service and anual service,i lose the map?
thanks!!!
Hypermotard 950 Full Termi reset
Re: Hypermotard 950 Full Termi reset
no danger with your bike, only the map activted by dongle for years 2010 to 2012 may have problems
Thanks, buddy! A few days ago I sent an email using the form, but I'm not sure if I did it correctly. I have the FT232RL ELM237 1.4, connected everything, and opened Melcodiag. By mistake, I didn't select the M3D control unit; I entered any model (I'm a disaster). I realized when, when I sent it, it told me there was an error. I tried repeating the process, but the blue button no longer appears. I've tried several times.jpl250rs wrote: Sun May 04, 2025 6:35 pm no danger with your bike, only the map activted by dongle for years 2010 to 2012 may have problems
Could you help me in any way? Don't get me wrong, I'm not in a hurry, but I don't know if I did the process correctly and the license is still pending or if I just messed up.
I'd be happy to buy you some beers.
Thanks, buddy!
if you back to anybike does the blue button appear again ?
you don't have a cle.lic file in your folder ?
I deleted all the files from my computer and reinstalled them. Only the blue button appears if I select any model; if I select m3d, it doesn't appear.jpl250rs wrote: Wed May 07, 2025 8:49 pm if you back to anybike does the blue button appear again ?
When I select any model, it identifies the VIN and the blue button appears, so I did it this way.
While reading, I found this thread where you indicate writing "no ecu data" to another user with the same motorcycle.
I followed the same process and wrote that on the first line. Now it's allowed me to send the information, and I got a message that the license will be sent to me shortly.
I hope everything is correct
Thank you very much!
All perfect! I can reset oil service and anual service on my 950 with original termi map, perfect! I send you some beers at paypal
