Good evening, today is 05/08/25.
I also have a problem with the "service data".
I follow the full procedure, and after several attempts I even disconnected the battery to try a sort of ECU reset.
Basically:
"Desmo reset" – OK
"Oil service" – OK
But when I perform the "service data" reset, it resets the "oil service" instead.
On the dashboard, "service date" flashes but nothing happens.
Can you help me? Thank you.
						Multistrada 950 2017 - annual reset
Re: Multistrada 950 2017 - annual reset
Hallo, ich habe das selbe Problem mit der MST950 2018
"File generated On 10.05.2025 09:33:50"
"Auto Detect Bike = MTS950"
"User Bike = 2018"
"Ecu = UUUU"
"Hardw = UUU"
"Softw = 95313053"
" vin DATA
vin 135A905A444D4141303541414A4230323931333355
11 PIDS active founds
020_80409000000049D0
024_00031028002004F9
080_2AB2B50020A00436
100_C712045000000413
018_0002A00080004C2B
019_9609600000000C4F
188_8001800180010B10
022_000000000003FB6E
023_0000005480010BB6
150_0900008D0001613A
210_00000041FF008136
"Vin = ZDMAA05AAJB029133"
"928FF74D"
ZDMAA05AAJB029133
"User Bike = 2018"
"Ecu = UUUU"
"Hardw = UUU"
"Softw = 95313053"
" vin DATA
"928FF74D"
ZDMAA05AAJB029133
Hello, is there any solution to the problem?
I am also having the same problem with Multistrada 950 2018, when selecting oil reset in app Windows plays the sound and nothing happens on the bike, and when choosing annual service option the bike flashes SERVICE DATE but doesn't seem to be resetting.
Tried multiple times and also running app as administrator but no luck.
Is there any update please?
"File generated On 15/06/2025 21:27:04"
"User Bike = Multistrada 950 / 2018"
"Hardw =
"Softw = A"
" vin 145A8F035A444D4141303541414A42303331303837
10 PIDS active founds
020_00407000000001F7
220_0000000000000AD8
022_000000000003F6EF
023_0000005480010637
188_8001800180010691
018_0002A000600048CF
019_960960000000083B
024_0001000000200039
080_2072BC0010000053
100_C712000000000063
"Vin = ZDMAA05AAJB031087"
"4E2C88EF"
ZDMAA05AAJB031087
0250010000000000
***reset***
***reset date interval***
service date : 250615
"Hardw =
"Softw = A"
"4E2C88EF"
ZDMAA05AAJB031087
0250010000000000
***reset***
Hello
Same for me on 2017 Multistrada 950
Connections OK
Licence OK
Press annual service reset then get oil service reseted and the annual service is still present
Connections OK
Licence OK
