Good evening, today is 05/08/25.
I also have a problem with the "service data".
I follow the full procedure, and after several attempts I even disconnected the battery to try a sort of ECU reset.
Basically:
"Desmo reset" – OK
"Oil service" – OK
But when I perform the "service data" reset, it resets the "oil service" instead.
On the dashboard, "service date" flashes but nothing happens.
Can you help me? Thank you.
Multistrada 950 2017 - annual reset
Re: Multistrada 950 2017 - annual reset
Hallo, ich habe das selbe Problem mit der MST950 2018
"File generated On 10.05.2025 09:33:50"
"Auto Detect Bike = MTS950"
"User Bike = 2018"
"Ecu = UUUU"
"Hardw = UUU"
"Softw = 95313053"
" vin DATA
vin 135A905A444D4141303541414A4230323931333355
11 PIDS active founds
020_80409000000049D0
024_00031028002004F9
080_2AB2B50020A00436
100_C712045000000413
018_0002A00080004C2B
019_9609600000000C4F
188_8001800180010B10
022_000000000003FB6E
023_0000005480010BB6
150_0900008D0001613A
210_00000041FF008136
"Vin = ZDMAA05AAJB029133"
"928FF74D"
ZDMAA05AAJB029133
"User Bike = 2018"
"Ecu = UUUU"
"Hardw = UUU"
"Softw = 95313053"
" vin DATA
"928FF74D"
ZDMAA05AAJB029133
Hello, is there any solution to the problem?
