Monster 696 2009 PIN Code Reset (Siemens ECU)
shwartz
Re: Monster 696 2009 PIN Code Reset (Siemens ECU)
Post by shwartz »
"File generated On 15.05.2025 21:53:05"
"ELM version : ELM327 v1.3a"
"User Bike = M696 2009"
"Ecu = S180040101"
"Hardw = QD082010"
"Softw = 82IU1MID"
" vin:100E5A8C3238353321323732383920202220AAAAAAAAAAAA
9 PIDS active founds
010_0000000000000000
080_0000000002000000
081_0300000000000000
100_0000000000200001
211_367B0035CE000000
280_20204D4F4E535445
290_5220363936202020
201_0000000000000000
020_0000005E9E0000
"Vin = 285327289 "
"BC6C64FB"
285327289hard :QD082010
soft :82IU1MID
023123
037F3133AAAAAAAA
>023123
037F3133AAAAAAAA
shwartz
Post by shwartz »
btw what pin code I must enter after reset? 00000 ?
ok it says ecu don't support this command.
maybe ducati don't use this command we can try a few ones different if you are not scare to reset other things like gears etc ..
once pin code is reset to 0000, it shall ask you to define a new one i guess
shwartz
Post by shwartz »
I think we can try it, no problem but I will read the eeprom content as backup with a programmer first .
