2024 SuperSport 950s
User avatar
mambrake
Post by mambrake »
I am unable to get LIC. below is what I am getting after the error: Be sure you are using the right software and the rights cables for connecting to your bike , data are incomplete!
300_4284000E0E67C343
Global_ vin 145A8F035A444D5641424453305242303030343335 vin 7F1A22 vin 7F1A22 vin 7F1A2213 PIDS active founds 080_2252BCC0052004F0 100_C806000FFF0013A2 018_0002A000F8C0C7A5 019_9609600000000780 020_0040E01000000AD0 188_8007803B80CF4267 022_000000000003F29B 18C_80178001000003E9 023_000000547F4B0265 024_0000000024200520 174_EC7F0060FA930C64 178_08800332F3800CDF 17C_06800100A8680CB6
ZDMVABDS0RB000435 OIL0_DES0
Debug report:
"File generated On 5/25/2025 7:04:54 PM"
"Auto Detect Bike = SuperSport S 939"
"User Bike = 2024"
" vin 145A8F035A444D5641424453305242303030343335
vin 7F1A22
vin 7F1A22
vin 7F1A22
018_0002A000F8C0C6B8
019_960960000000069D
080_2252BCC0052002BE
100_C806001FFF0011BD
020_0040E00000000BE8
230_00001C0000000DA7
188_800B803780CB40AD
022_000000000003F0A1
18C_800B8001000001C8
023_000000547F3B0074
174_F07F0058F7930F37
178_F87F0000F0800F22
17C_F27F010073680F60
024_000000002420036E
"Vin = ZDMVABDS0RB000435"
"02F9EDE3"
ZDMVABDS0RB000435
UPDATE:
Got a message that mail has been sent after adding "no ecu data". The software only picks up my VIN and that is it. I am using ELM327 V1.5 with FTDI chip
I trust In GOD :geek:
User avatar
mambrake
Re: 2024 SuperSport 950s
Post by mambrake »
After receiving the LIC the software behaves the same. All I see is the VIN and the miles are read wrong. Report beneath. I am using Version 1.5 of ELM327 with FTDI chip
"File generated On 5/26/2025 11:46:55 AM"
"User Bike = 2024 supersport"
vin 7F1A22
vin 7F1A22
vin 7F1A22
18C_800B800100000C49
023_000000547F470BE7
174_F47F0054F79309C2
178_0A800000EF8009E8
080_21C2BCC005200D56
100_C806000FFF001C19
17C_FC7F01009868093F
020_0040E00000000669
024_0000000024200EEF
150_0002107E00000AB4
018_0002A000F8C0C2CC
019_96096000000002E9
188_7FF7803780CB4C07
022_000000000003FC3D
"02F9EDE3"
ZDMVABDS0RB000435
This is what I see
This is what I see
i'm not so confident with the version1.5 but i see an issue with your bike
software has identified it wrongly
have you change the bbs or ecu ?
User avatar
mambrake
Post by mambrake »
I bought the V1.4 advertised on amazon for this program. This is the log. I will add the setting on the program. Let me know if i am doing anything wrong. My ECU is continental M4C, and I get the wrong miles count on the software. Im at 9000 miles. I bought the bike at the auction. Not sure if anything was changed on it.
"File generated On 5/28/2025 7:51:04 PM"
vin 7F1A22
vin 7F1A22
vin 7F1A22
174_EE7F0059EC930DB0
178_FA7F0731C7800DF9
17C_0680010098680D83
024_0000000000200162
020_0040111000000A29
018_0002A0000000451E
019_96096000000005BA
080_2102BCC00520013A
100_C806001FFF0010A0
188_800B802380D34F93
022_000000000003FF1A
18C_80178001000000CE
023_000000547F430FBE
240_0000012D00145771
*Ecu found on : 7D4 ,7DC*Ecu found on : 7DF ,7EB*Ecu found on : 7E0 ,7E8*Ecu found on : 7E1 ,7E9*Ecu found on : 7E2 ,7EA*Ecu found on : 7E3 ,7EB"
"DTC = FC7F01007F680F6B FC7F01007F680F6B00800100796803E9 FC7F01007F680F6B00800100796803E9C806000FFF001A57"
"02F9EDE3"
ZDMVABDS0RB000435
i see DTC is not right
it didn't switch ecu but give the content of the buffer
that's explain why you have no answer on 7e2.
if you wanna see the dtc on 7e2 , don't do a scan , but directy press DTC button , it's by default on 7e2
for the mileage , it's probably my fault , it's not debugged on your bike yet
User avatar
mambrake
Post by mambrake »
I got the error codes. I cleared them and will see if they come on again. I never had the check engine light on for these errors. I removed the gas tank and all the gas to fix the tank so maybe this triggered that code for the sensor. I had the cluster disconnected so maybe that caused the IMU code.
Error codes
Error codes
some ghost errors can come when the battery drop below 12V
nothing to worry if that don't comes back after you did a small run
