I haven't received the license registration email.
wing.n283
Post by wing.n283 »
Dear JP250rs, Nice to meet you.
I live in Japan.
I applied for a scrambler sixty2 (400cc) license 2025.5.23.
I haven't received the license reply email.
I submitted my email address according to the application, but I think I may have sent it to the wrong email address, so I am emailing you.
I accidentally typed in my email address as (,com) instead of .com.
I submitted a legitimate request again using the blue button on 2025.05.29, so could you please check it?
I would like to use your application to reset the Desmo service.
Thanks for developing a great application.
Re: I haven't received the license registration email.
found you
you wrote your email with a ",com" instead a ".com"
wing.n283
Post by wing.n283 »
I received (lic.cle).
Apologies for the typo in (,com).
However, the desmo reset has not yet been successful.
When I check the debug, (lic found) is displayed.
However, (Desmo reset) is not available in the MelcoDiag software.
Even when I click it, I still can't perform the reset operation.
I have copied the debug below, so could you please check it?
Is there a problem with the cable I'm using?
Can't MelcoDiag be used with sixty2?
Am I doing something wrong?
Please let me know if you have any advice on how to solve this.
"File generated On 2025/05/31 16:29:12"
"Auto Detect Bike = Scrambler"
"User Bike = scrambler sixty2 / 2018"
"Ecu = 5WY8691-AA"
"Hardw = QD0H1010"
"Softw = 1DABAAC1"
" vin:100E5A8C3430303021313739373336202220AAAAAAAAAAAA
5 PIDS active founds
081_00000000C8000000
020_52B8C00000000000
100_00000A0000040001
022_0000000000000EAC
240_85A0C00000289A00
"Vin = 4000179736 "
"C6F1CA69"
"Bike = 5"
000179736hard :QD0H1010
scrambler detected
soft :1DABAAC1
check if cle.lic is not locked , in file properties , then try to run melcodiag with admin rights as well
wing.n283
Post by wing.n283 »
Thank you for your reply.
I followed your instructions to launch MelcoDiag with an account with permissions and unlocked each file and software in the file properties in Windows.
However, the only option to reset is (Key reset.)
Is there anything else I should try?
haven"t you ask a licence for different bikes ?
you shall not mix the files
wing.n283
Post by wing.n283 »
Thanks for the reply.
I only requested a license for the scrambler sixty2.
I did not request any other motorcycles.
I don't have the files to mix.
I only have one lic file
Is there a case where it would be better to use JPDiag instead of MelcoDiag? If necessary, I would like to download it and request the license again.
only melcodiag is suitable for you
jpdiag is for older bike that not using canbus
i resent a lic file
wing.n283
Post by wing.n283 »
I have received the resent lic file.
Thank you.
I found out that only MelcoDiag can be used with scrambler.
I can't work on it right away, but I'd like to try again.
Is the file itself the same as before?
Should I uninstall MelcoDiag and install it from the downloaded file?
Or should I just update the lic file to the latest one?
Run with administrator privileges.
I will unlock it from the properties.
you shall delete previous cle.lic then use the new one , they are different.
no need to re install melcodiqg
