Monster 696 2009 PIN Code Reset (Siemens ECU)
shwartz
Re: Monster 696 2009 PIN Code Reset (Siemens ECU)
Post by shwartz »
"File generated On 15.05.2025 21:53:05"
"ELM version : ELM327 v1.3a"
"User Bike = M696 2009"
"Ecu = S180040101"
"Hardw = QD082010"
"Softw = 82IU1MID"
" vin:100E5A8C3238353321323732383920202220AAAAAAAAAAAA
9 PIDS active founds
010_0000000000000000
080_0000000002000000
081_0300000000000000
100_0000000000200001
211_367B0035CE000000
280_20204D4F4E535445
290_5220363936202020
201_0000000000000000
020_0000005E9E0000
"Vin = 285327289 "
"BC6C64FB"
285327289hard :QD082010
soft :82IU1MID
023123
037F3133AAAAAAAA
>023123
037F3133AAAAAAAA
shwartz
Post by shwartz »
btw what pin code I must enter after reset? 00000 ?
ok it says ecu don't support this command.
maybe ducati don't use this command we can try a few ones different if you are not scare to reset other things like gears etc ..
once pin code is reset to 0000, it shall ask you to define a new one i guess
shwartz
Post by shwartz »
I think we can try it, no problem but I will read the eeprom content as backup with a programmer first .
sinank
Post by sinank »
With the model of Ducati you must receive unique code card with the bike. This code is coded inside your screen or ECU Iam not sure. But I am sure that there is no way to reset this secret code, it is set from factory. If you loose your both keys you need this code, if you loose the key card you need new dashboard and key set and card together. There are some guys who can manually enter your ECU and figure out the embedded code, you can check online.
shwartz
Post by shwartz »
I have taken away this code from my bike already.. I have read the eeprom to do this. So finally I have done to do pre-code a new key and wrote it to the bike.
Thanks all for the answers
interresting, can you share the bin file before and after yout edit ?
