Panigale V4 2022 Annual Service/ Desmo not working
joxi1000
Re: Panigale V4 2022 Annual Service/ Desmo not working
Post by joxi1000 »
Hi folks,
i was abroad some time now I read you are struggling aswell.
@jpdiag, is it possible that Ducati changed something at the dash communication with EURO5? It seems, that just Modells from 2022 have this problem.
Disconnecting the battery for a CL.30 Reset changed nothing aswell.
Maybe somehow the communications from the dashboard changed.
can you try each of the 3 buttons related to annual service data , and post the debug report ?
between each attempt , check if the annual is reset to know which button did the trick ( if one does)
check last version 2.0.5.0
joxi1000
Post by joxi1000 »
So first reset Oil service, second annual service, third desmo and then trigger the report if the annual works?
as i understood, oil or desmo reset works , just the annual service data couldn't be changed.
so i created 3 buttons only for annual service , i need report for each annual buttons
joxi1000
Post by joxi1000 »
Hi jpdiag,
So this is annual 0:
"File generated On 25.08.2025 21:00:22"
"Auto Detect Bike = Panigale V4 22"
"User Bike = Panigale V4 2022"
"Ecu = ÌÌÌÌ"
"Hardw = ÌÌÌ"
" vin 145A8F035A444D3344303041414E42303032343734
020_0043510000008A7F
080_1DC226C0252003C3
100_C8120150160002C3
018_0002A000400848A5
019_96096000000308EF
08A_0000000000002865
120_2A04800000012C7C
124_C600000000000C3A
200_0000000000000C96
330_165490C591BF088A
250_0000000000000D8B
174_F07F00539B6B0CD4
024_000000000000047E
022_000000000003FF1A
"Vin = ZDM3D00AANB002474"
"BC967C37"
ZDM3D00AANB002474
***reset annual***
0250010000000000
023E00
027E001200000000
annual service 1:
"File generated On 25.08.2025 21:01:58"
and the third "change service date":
"File generated On 25.08.2025 21:03:07"
"Ecu = ÌÌÌÌ"
"Hardw = ÌÌÌ"
"BC967C37"
ZDM3D00AANB002474
***reset annual***
0250010000000000
023E00
027E001200000000
023E00
027E001200000000
service date : 250825
031A9100
065A910025061900
031A9300
037F1A2225061900
***reset annual***
0250012225061900
>023E00
027E001225061900
>023E00
027E001225061900
031A9100
065A910025061900
031A9300
037F1A2225061900
***reset annual***
031A91250825
065A912525061900
031A93250825
037F1A2225061900
***reset annual***
031A91250825
065A912525061900
031A93250825
037F1A2225061900
"Ecu = ÌÌÌÌ"
"Hardw = ÌÌÌ"
"BC967C37"
ZDM3D00AANB002474
***reset annual***
0250010000000000
023E00
027E001200000000
023E00
027E001200000000
031A9100
065A910025061900
031A9300
037F1A2225061900
***reset annual***
0250012225061900
>023E00
027E001225061900
>023E00
027E001225061900
031A9100
065A910025061900
031A9300
037F1A2225061900
joxi1000
Post by joxi1000 »
The dash shows annual service dated since 19/06/2025, so none of the three created buttos worked sorry.
ok thanks , at least now i can check the correct date,
i'll keep investigate
VioDuskar
Post by VioDuskar »
I'm interested in this as well, as I have a 2024 Diavel V4 that the annual service button isn't working for.
I have the ELM V1.4, not the 1.5 though.
I tried both the website version of melcodiag, and the beta version with all three reset buttons listed here. I have not had luck with either.
I also attempted to reset the oil service and didn't have any luck either.
I have the Termignoni upmap, but reverted to original map before attempting any work with melcodiag.
revert map is not necessary on newer bikes like yours
i'll keep working on this function
ajcorrea
Post by ajcorrea »
@jpl250rs
There´s some commands that i can try to execute in a "OBD2 direct shell" ?
I have ELM 1.4 and 1.5 and a Multistrada V4S
