Cable connection error Ducati Streetfighter 848
Ducatisf848
Post by Ducatisf848 »
Hello, I have been trying to register for the software however when I plug up the diag tool to my bike and run the software I keep getting a CAN error check cable. I tried the same cable on 2 other bikes and it works just fine. Can someone explain what the issue might be?
Thank you!
Re: Cable connection error Ducati Streetfighter 848
can you tell what cable you use ?
and confirm you are using jpdiag too , not melcodiag
you can't proceed with the registration untill you fix the communication problem
