License process
tarmac31
License process
Post by tarmac31 »
Hey JP,
I've tried a few things to get the license to come through but without success, can you advise?
Here's what I did on my last attempt.
1. Connected the laptop to the internet, connected the OBD2 to the bike and laptop.
2. Turned on the bike ignition (without starting). OBD2 has red light.
3. Started Melcodiag on the laptop. Connected using correct com port and baud rate. Lights flash on OBD2 and data is received
4. Entered the bike make/model/year. Selected Oil Service. Selected Anybike. Debug Information for Report and registration remained ticked.
5. Clicked write report. File was written to the Melcodiag folder - I did find a problem previously here, that if windows folder protection is on, the file cannot be written, The fix was to allow write in the windows security settings.
6. Clicked the Get License Blue button and got to the registration webpage, and noted the prefilled information with the 4 empty lines at the top.
300_408400120715CEBF
Global_ vin 145A8F034D4C30344D303041415054303030363830 vin 7F1A22 vin 7F1A22 vin 7F1A2214 PIDS active founds 024_0000000000000EAC 080_22B2BCC000200E73 100_C712000000001E08 018_0002A00020004B88 019_9609600000030BC8 020_004031100000003A 188_7FFB7CAF804345B3 022_000000000003F5C8 18C_80037FFB0000060B 023_000000547FC305A5 174_F87F004FE58B035D 178_08800E4762660350 17C_F47F010014740336 240_0000012D0014566C
ML04M00AAP******* OIL1_DES0
7. Added the required info Bike and email, then clicked send which gave an the error "Be sure you are using the right software and the rights cables for connecting to your bike , data are incomplete!
an m3c ecu use m3c9 software , a fuji ecu use melcodiag , a marelli 5am,5sm,59m,miu use jpdiag1
back, clic here
8. I checked the forum and a post mentioned adding no ecu data to he top line so I did that and got the Mail sent message. But still no license came through.
This was the diag file contents (VIN obscured for forum post).
https://jpdiag.akress.com/jpdiag.php?Lic=: : : : : 300_408400120715CEBF: 18_: 80_: 100_: Global_ vin 145A8F034D4C30344D303041415054303030363830
vin 7F1A22
vin 7F1A22
vin 7F1A22
: ML04M00AAP******* OIL1_DES0&UID=707818E5
Re: License process
hope you got it now
it's not an automated process , i need to be arround to generate the key , so it may need 24hours before getting it
by the way the step 5 create a report is not needed in the registering process .
it's usefull only for debugging in case of troubles by posting this report on the forum
tarmac31
Re: License process
Post by tarmac31 »
Thank you. I wasn't sure if was automatic or manual so i appreciate you patience. There is a slight delay in me testing this as I flattened the battery with he tests I was doing so waiting for a new lithium type charger to arrive. Hopefully today.
Will update soon.
tarmac31
Re: License process
Post by tarmac31 »
Here is something unexpected.
I got the charger and recharged the battery. When connected, The service light was no longer visible. I hadn't reset with Melcodiag yet.
I had to reset the date and time through the dash, so I did that, and while I was in there, I also checked the due date for the maintenance and it's listed date is still due a few days ago (mid May), so the light should be on (I think), but it's not.
Has anyone else experienced that? Should I attempt to reset it anyway?
I have also checked that Melcodiag is registered license is valid (and I'll do a donation when I get home later tonight).
