Issue connecting to Multistrada 1200s 2015
hORn
Post by hORn »
Good day,
Recently tried to use Melcodiag of last version to connect to my bike.
I have Vgate vLinker MC+ adapter which supports almost any ELM327/329 software. Melcodiag reports adapter as ELM327 v2.2.
The issue is either it connects and gets only VIN and model name, when using "Any bike" option, but no HW/SW data and while register attempt is says data is invalid. Or just connects and no data at all, once "M3C.." option is used. Also tried all different COM port speed options.
Is the problem in my adapter or am I simply doing something wrong?
PS: the same adapter, but other software like CarDiag, reads all standard OBD data well.
Thank you!
Re: Issue connecting to Multistrada 1200s 2015
can you post the report here ?
hORn
Post by hORn »
Is it the one with data when trying to register? I've tried with button "Write report", but despite is says report has been written, I didn't find a file (and clipboard is empty too).
Code: Select all
300_3F98000038B449D9
Global_ vin 145A8F035A444D4141303041414642303031353334 vin 7F1A12 vin 7F1A12 vin 7F1A1217 PIDS active founds 178_0080032370770163  018_0002A00082004B7B  019_9609600000000B1C  17C_000000000A940148  022_000000000003FA73  023_000000FC807F0A8C  188_80037B237F8B4AA0  020_0000950000004FB0  024_000000000000047E  080_192000003020043D  100_C7120360350004D6  174_118000007E6A0268  230_01801000001C00DA  607_01FE0A0155555555  587_41FE0A00AAAAAAAA  150_0000007B0000660D  210_00000031FF00D640
ZDMAA00AAFB001534 OIL0_DES0
no this is not right
you posted a part of the registration link
i need the content of the debug report .
( button create report ) check for MelcoDiag.exe.debug.txt
hORn
Post by hORn »
Ok, I've got it finally.
PS: Once MelcoDiag is put into "Program Files (x86)" folder, it can't write files inside, likely due to missing permissions.
Code: Select all
"File generated On 03/09/2025 21:51:32"
"Software version 2.0.4.6"
"ELM version : ELM327 v2.2"
"Auto Detect Bike = MTS1200"
"User Bike = mts1200-any"
" vin 145A8F035A444D4141303041414642303031353334
 vin 7F1A12
 vin 7F1A12
 vin 7F1A12
20 PIDS active founds
174_248000006D6A08CC
178_118002207D770827
17C_0000000039940819
024_0000000000000D8B
080_1930000030200DDC
100_C712036033000D26
020_0000950000004645
022_000000000003F1BC
023_000000FC806B01DA
188_7FE77B2B7F8B41DB
240_0078600442000C02
018_0002A00082004393
019_96096000000003F4
130_0000050003E60600
120_4A44771D14041A14
620_38B440001A010000
150_0000007800006F42
210_00000034FF010FD2
230_01801000001C092F
"Vin = ZDMAA00AAFB001534"
"A2E75034"
CAN ERROR
CAN ERROR
CAN ERROR
ZDMAA00AAFB001534
hORn
Post by hORn »
Any chance to understand what could be wrong?
yes you use an old melcodiag version , i think the last one shall works better
except this , it seems not so bad
