Cant get software and Hardwareinfo on two Bikes no License
BlackMamba
Post by BlackMamba »
i can`t get Software and Hardwareinfos. Fin and Modell are displayed
So i canˋt get a license because any data are missed.
Used cable ELM327 1.4b (ODBLink SX).
Bike 1 Monster821
Bike 2 Monster1200R
can you give me a Licence for both Bikes?
Report for Monster 1200R:
vin 7F1A12
vin 7F1A12
vin https://jpdiag.akress.com/jpdiag.php?Lic=: : : : : 300_830683101F770540: 18_: 80_: 100_: Global_ vin 145A8F035A444D4D41303041414742303030383833
7F1A12
024_0000000000173246
020_040000015E003800
080_80004000000000C8
018_0000460100000003
120_7B05010000000602
300_030683101F770540
230_0000000000080000
240_0394D00000A89C00
100_034128387C38D700
150_0000404B404B56B3
160_000040408081CBCB
190_3800000000C9905A
210_0000000000000000
: ZDMMA00AAGB000 OIL0_DES0&UID=5A0DC90C
Report for Monster 821:
https://jpdiag.akress.com/jpdiag.php?Lic=: : : : : 300_4104831047550540: 18_: 80_: 100_: Global_ vin 145A8F035A444D4D36303441414742303230373936
vin 7F1A12
vin 7F1A12
vin 7F1A12
024_0000000000133546
100_614128387538D700
150_0000404B404B5232
160_000040408180CBCB
190_4000000000C99051
018_0000560000000003
020_0400000146303600
300_C104831047550540
240_8394D00000A89500
120_7503010000000002
: ZDMM604AAGB020 OIL1_DES0&UID=5A0DC90C
Best regards
Re: Cant get software and Hardwareinfo on two Bikes no License
those are not report but registration links
to make a report , press create report button
BlackMamba
I got the two license files. But the program still reports "get license".
The License file is in the Same Folder as the Program.
I have merged the two files with this:
inside a terminal you can type this
copy /b cle1.lic + cle2.lic cle.lic
In i copy only one of the files in the Folder, the result is the Same.
you maybe need to unlock your cle.lic file
BlackMamba
How can I do that? Permissions are all set.
right clic on cli.lic - properties and untick lokcked
or be sure you didn't rename it viewtopic.php?t=5
BlackMamba
So, I couldn't unlock the files. I had transferred these via USB stick. After I logged into my e-mail account on the PC on the melcodiag works and downloaded the files, I was able to release them. I have merged the two files as described by you. Now everything runs as desired and I was able to reset the service indicator on the 821. Thank you for your support.
