2015 Multistrada 1200 S PIN code reset
AlexRq
Post by AlexRq »
Hi Jp,
Do you know if PIN code reset is allowed via Melcodiag ? I am not able to try until Monday, so it would help me to know what to expect.
Was the PIN code reset successfully in the past ?
Thank you !
Re: 2015 Multistrada 1200 S PIN code reset
it works on some models ,
it's worth to try it
AlexRq
Post by AlexRq »
Thank you !
I will try on Monday and share the result.
AlexRq
Post by AlexRq »
hi Jp,
Just tried the melco on 2015 Multistrada 1200 S and it seems that PIN code reset is not working. Also it seems that annual service reset is not working either.
Here's the report:
"File generated On 28.10.2025 07:39:48"
"Auto Detect Bike = MTS1200"
"User Bike = 2015"
"Softw = 10SW037916U"
" vin 145A8F035A444D4141303041414642303034373631
vin 7F1A1255555555
vin 7F1A1255555555
vin 0C5A953130535730333739313655
024_0000000000000EAC
080_1AF0000050200EBC
100_C712036033000E01
022_000000000003F7F2
023_000000FC7FF307BD
174_0B8000001F6B0D91
178_E47F0624BD780D22
17C_0000000037950D35
188_802B7C1F804347C2
020_0000750000004983
018_0002A0006200466A
019_960960000000069D
*Ecu found on : 7DF ,7E9*Ecu found on : 7E0 ,7E8*Ecu found on : 7E1 ,7E9*Ecu found on : 7E7 ,7EF"
"Vin = ZDMAA00AAFB004761"
"DTC = NO DATA NO DATANO DATA NO DATANO DATANO DATA 1020580AC15520D20420D20620C02820C12220D00220C12120D00520D10220C167205555 0258005555555555 037F181100000000 037F181100000000037F181100000000 037F181100000000037F181100000000037F181100000000 037F1811 037F1811037F1833 037F1811037F1833037F1833"
"A48D2CFE"
ZDMAA00AAFB004761
10sw software is still a mistery for me , same software on a diavel , reset works but not on MTS
AlexRq
Post by AlexRq »
Oh, I understand ! :(
Thank you !
