Partial data read - only VIN
littlebouggy
Post by littlebouggy »
Hi Everyone,
I'm curious if anyone else has encountered something similar to my situation.
I'm trying to reset the yearly service on my bike. But can't seem to be able to fully connect to the ECU, it won't read the type.
Bike: 2021 Supersport 950S.
Cable: bought from BMDIAG for melcodiag compatibility. Link https://www.bmdiag.co.uk/bmdiag-obd-int ... n-software.
Melcodiag version 2.0.4.4
I bought the cable for the Melcodiag compatibility.
Quote on the webpage:
"V1.4 ELM327 Compatible
FTDI Chip
Compatible with the Triumph Tiger Tool, MultiECUScan, MelcoDiag and all good OBD2 software that requires an V1.4 ELM interface"
When I try connecting to the bike, it returns the VIN of the bike, but not the ECU Type.
I'm open to suggestions.
Thanks in advance for your help!
KR,
L
2002 Monster 620 IE Black
2021 Supersport 950S - current
Re: Partial data read - only VIN
with some bike , i don't get all data ,
the most important is that the vin is readen and your bike identified by melcodiag .
so the right commands can be used
can you put the debug report content here ?
littlebouggy
Salut JP,
Thank you for the fast reply!
Here's the log file:
"File generated On 02/03/2025 18:21:30"
"Auto Detect Bike = Supersport 950S 2021"
"User Bike = SS 950S 2021"
"Hardw = """
" vin 145A8F035A444D3156303041414D42303032303132
018_0002A00082004393
019_96096000000003F4
020_00409500000048B3
024_000000000020007F
174_D07F004F2C7F0BE4
178_0080015374800B83
17C_068001008C9E0B84
080_2242BCC0250000D5
100_C812001FFF001F0A
188_7FF7804780CB4EC6
022_000000000003FE07
18C_7FFF800300000F75
023_000000547F3B0ED2
"Vin = ZDM1V00AAMB002012"
"88BF4EAB"
CAN ERROR
CAN ERROR
ZDM1V00AAMB002012
Interestingly, a bit over a year ago I used the diagnostic cable of a friend of mine (clone from aliexpress) and that worked perfectly. I already requested a license using his cable, thinking, I'll be able to use it once I get my own cable.
Thanks for your help!
I don't think the VIN has changed right ?
Melcodiag is not finding the cle.lic file you lost the one you got last time ?
what happen when you fill the registration page and submit it ?
littlebouggy
No, the VIN didn't change.
I just tested with the license file. The software connects to the bike like before, sees VIN and bike model software version, no ecu type. But I tried resetting the annual service interval, and it worked. :)
I was curious if anything else worked, but sadly didn't seem to. (I'm still happy about the service light disappearing).
Merci beaucoup JP pour la software.
JohnDeere
Post by JohnDeere »
Just having this issue.... the software is only pulling the VIN number and nothing else. clicking the submit button does nothing. :0(
striz
Post by striz »
hi, I had the same "problem" on my supersport.
interval reset and annual service reset are OK ! very important. but it would be nice to have all the functions available !
even the mileage on the main page do not match.
thanks for the work you do
Striz
"File generated On 30/12/2025 12:42:38"
"User Bike = Spersport"
"Ecu = ÌÌÌÌ"
"Hardw = ÌÌÌ"
" vin ******************************************
18C_7FEB8001000007AB
023_000000547F7B06D0
080_20A2BCC0052002C8
100_C81201AFFF00119C
174_06800041E0930520
018_0002A00040C04CA8
019_9609600000000C4F
178_02800842877A051E
17C_F67F010058690527
024_000000000000032D
020_0040501000000234
188_80037D0B808B4798
022_000000000003F7F2
"Vin = *****************"
"DTC = 055801107D280000"
"4F8FE2D0"
065A9200251230
065A9200251230
065A9200251230
065A9200251230
065A9200251230
a screenshot of the read annual would be usefull to check if the data are well readen
striz
Post by striz »
This?
in reset tab you have a button read annual , i see you pressed it;
i would like to see what it is displayed
