2013 Hyperstrada All Buttons greyed
Posted: Wed Jan 21, 2026 5:53 am
by yorogen
Hello, the buttons in Melcodiag are all greyed out. Below is the debug report. The cle.lic file has been added to the Melcodiag folder. Is there something else I should try? Thanks
"File generated On 2026/01/21 水曜日 11:41:39"
"ELM version : ELM327 v1.4b"
"Auto Detect Bike = If your bike is not a 2010 to 2012 made ,please contact jpl250rs with your VIN and model bike"
"User Bike = Hyperstrada821/2013"
"Softw = 12"
" vin 145A8F035A444D423230314A414442303031333830
020_0B009B03A8003000
018_00004E0000000005
024_122724CB00000000
080_00114450000000C8
240_A188E00000A89800
230_0000000000080000
300_8003852065B20980
120_790B010000000402
160_C8C800006564CACA
150_0000545058508007
100_401228457730D700
210_0000000000000000
"Vin = ZDMB201JADB001380"
"70689257"
ZDMB201JADB001380
Re: 2013 Hyperstrada All Buttons greyed
Posted: Wed Jan 21, 2026 8:49 pm
have you check the part troubleshooting from here ?
viewtopic.php?t=5
i see you have not a Eu / Us font on your system , it could be the root cause of the not recognization of the licence
Posted: Wed Jan 21, 2026 11:33 pm
by yorogen
My bike is Japanese spec, so maybe Japanese fonts are being used.
Is there any way to authenticate the license? Thank you in advance.
Posted: Thu Jan 22, 2026 5:28 pm
even your computer use japaneese font. 水曜日
if you can't use english font on your computer then i have to find an different way , but that wouldn't be the fastest one
Posted: Fri Jan 23, 2026 12:29 am
by yorogen
So the problem was with my computer settings. I'll change the settings to English and try again.
Thank you.
Posted: Fri Jan 23, 2026 3:08 am
by yorogen
I tried again, but a new license could not be issued because the ECU is already registered. I will describe the debug text below.
"File generated On 1/23/2026 11:46:37"
"User Bike = Hyperstrada 2013"
"Softw = 12"
15 PIDS active founds
020_0B00FF03C0002C00
018_0000420000000005
080_00114460000000C8
024_40EEC42E00000000
300_4003852065B20980
120_7E0B010000000402
620_196C800000000000
160_C8C800006564CCCC
150_000049504D508000
100_0012082C7B2CD800
240_2188E00000A89D00
"70689257"
ZDMB201JADB001380
Please let me know if there is anything I can do. Thank you.
Posted: Sun Jan 25, 2026 4:23 am
by yorogen
Good morning.
Today, I tried using the license file I received initially.
Of course, I copied it into the same folder as Melcodiag without changing the file name. The license file has been unlocked.
As a result, the debug text changed from 'lic not found' to 'lic found', but it still says 'not registered'.
Do I still need a new license file?
I would appreciate your assistance in allowing me to use Melcodiag.
I am attaching the debug text below.
"File generated On 1/25/2026 12:53:07"
"Softw = 12"
020_0C00FF03D6003100
018_00005E0000000005
024_A052889E00000000
120_7C0B010000000402
240_A188E00000A89C00
150_00004D5051508000
100_601208307A31D800
"70689257"
ZDMB201JADB001380
Posted: Sun Jan 25, 2026 9:02 pm
i checked the lic it's ok ,
that should works , i'm pretty sure it comes from the japaneese fonts.
i upload v2.0.4.9 , you can give it a try , i tried to mange it differently for the fonts issues
Posted: Mon Jan 26, 2026 1:09 am
by yorogen
Jp250rs
Thanks to you, Melcodiag is now working perfectly.
You are truly an amazing person.
With this, my Hyperstrada 821 should be able to stay in great condition.
I am grateful for your technical skill.
yorogen
