I am riding a 2025 Ducati Streetfighter V2 and am not sure if the latest Melcodiag should/will work to perform a service reset? I am able to connect and can see all my ECU info, VIN, etc. and have tried the Service 0 and Service 1 resets without success. I am at approx. 1400 km and get a banner at key on that says I am 400 km past service, service icon bottom left of TFT, and flashing tach display when RPM is over 6000.
Like many of you I suspect, I have done all my basic service on my bikes for over 50 years and the lack of a simple owner reset sequence is in my opinion the only flaw in an otherwise fantastic motorcycle.
I thought I would post here prior to contacting the developer. Thanks for any ideas or suggestions.
Service reset 2025 new 890 V2 models?
Re: Service reset 2025 new 890 V2 models?
i have no clue with this bike , if i check here reset are successfull on 2023 models
your tests will tell use , have you tried to presse reset service before pressing annual ?
is your bike is well identified by the software ?
viewtopic.php?t=45
viewtopic.php?t=45
I'm having the same issue on my 2025 Panigale V2, I can connect to the bike and I've ran the Service Interval, Annual service 0 and Annual service 1 but with no success to reset the Service warning or the banner.
It seems to not be reading some info properly as well, ECU appears as N/A and some values are not correct (Milage is much lower than real and RPM shows 8000 when the engine is not even turned on)
Should it be like this or did I do something wrong?
i patched Melcodiag .
dtc now shall be ok , but a lot of functions still need to be developped
I confirm that on 2.0.5.2 DTC seemed to run fine when I tried it.
I'll gladly keep trying as the software get updated and test different things if you want to!
Anything so that we can fully do our own maintenance by ourselves.
freefallen
I have a similar issue with Multistrada 2024 V4.
Melco app seems to recognize my bike showing the correct VIN. Some specs are way off, like temps and mileage. When I click on Service Interval button or Annual Service 0 or 1 or change service date, the OBD II illuminates serious of lights, then I hear the beep on my laptop, but it does nothing. My bike still shows oil service required. For reference, my laptop has Windows 11.
Should I open a new thread or it's ok to continue here?
- melco.jpg (212.92 KiB) Viewed 97 times
