Scrambler 1100 2022 help please
Franksgarage
Post by Franksgarage »
Hi everyone. I found some old threads on other pages in regards to accessing the ECU on Scrambler 1100 models. I have a 2022 model and I can only retrieve the VIN and no other info using the latest Melcodiag and selecting 'Any bike' as I read that the bike has an M4C ecu. Any help from here is greatly appreciated.
Also I should mention I used a 6 pin Euro 5 red adapter to OBD, then to my ELM to USB on my Windows 10 PC. I have used the same ELM to USB with a 4 pin Ducati plug before with success on older models.
Thank you guys
Re: Scrambler 1100 2022 help please
if the bike is recognized by melcodiag with one of the settings , that should be ok
have you a picture of the 6 pins adaptor ?
Franksgarage
This one
This one
fabian.m
Post by fabian.m »
Any updates on this matter? Have you managed to connect and perform diagnostics on the bike?
I have the same issue, trying to connect a Scrambler 1100 pro (MY2021) with the 6 pin connector using a similar adapter, but it won't read out much detail, only the VIN, no ECU type, no HW version, no SW version... Reading DTCs only returns a response from one control unit: No response from 7DF, 7E0, 7E1, 7E2. Positive response from 7E3 only. Service reset doesn't do anything either...
