Hyper950
Posts: 4 Joined: Sun Mar 02, 2025 11:01 am
Post
by Hyper950 » Sun Mar 02, 2025 11:42 am
Hello.
I'm using ELM327 V1.4 FT232RL 25K80
After connecting to bike its look like:
When trying get licence:
But after sending the sheet I got message:
Be sure you are using the right software and the rights cables for connecting to your bike , data are incomplete!
an m3c ecu use m3c9 software , a fuji ecu use melcodiag , a marelli 5am,5sm,59m,miu use jpdiag1
BTW:
MelcoDiag.exe.debug raport looks like:
Code: Select all
"File generated On 2025-03-02 11:10:36"
"Auto Detect Bike = Hyp 950"
"User Bike = 2020"
" vin 145A8F035A444D4242303041414D42303037333437
vin 7F1A22
vin 7F1A22
vin 7F1A22
018_0002A000420048FC
019_960960000000083B
024_0000000000000117
080_23D23DC00520012D
188_7FF77E3F8043465F
022_000000000003F6EF
023_000000547FBF06DE
100_C8120040000001B6
174_F87F00512F6A0338
178_FC7F085FDB6A035D
17C_02800100A17C037E
020_00405500000001E9
230_00801C00000004F2
"Vin = >I erased it<"
"A2866F33"
>I erased it<
So. What I done wrong? I would like to reset a desmo service.
Posts: 1191 Joined: Sat Jan 11, 2025 2:36 pm
Post
by jpl250rs » Sun Mar 02, 2025 1:37 pm
ok , in your case as the ecu model name is not grabbed
before you press send button on the register page , replace the 1 st empty line with the mention : no ecu data
once the field will be populated it shall continue the registration process
Hyper950
Post
by Hyper950 » Sun Mar 02, 2025 2:25 pm
Thanks for your reply.
Problem solved.
Everything works fine.
All services have been reset correctly.
Best Regards
Post
by jpl250rs » Sun Mar 02, 2025 4:19 pm
what did you reset exactly ?
i'll make a new thread with the successfull resets
Hyper950
Post
by Hyper950 » Sun Mar 02, 2025 5:01 pm
I have used with successful this two options:
On dashboard:
schmutzlutz
Posts: 4 Joined: Mon May 05, 2025 7:49 pm
Post
by schmutzlutz » Mon May 05, 2025 7:58 pm
Hey guys,
I also have an Hypermotard 950 (Build 2019) and had the same issue that Melcodiag could only read VIN and "Hyp 950". After following your post to mention "no ecu data" I got the license, but unfortunately the reset of the annual oil service does not work.
The only difference I see so far is, that Hyper950 requested OIL0_DES1 while I requested OIL1_DES0.
Do you think that could be the reason? Here my debug report:
Code: Select all
"File generated On 05.05.2025 21:27:40"
"User Bike = 2019"
" vin 145A8F035A444D4242303041414B42303033333033
vin 7F1A22
vin 7F1A22
vin 7F1A22
17C_F47F010027790F35
100_C812000000000DBE
018_0002A000420065FA
019_96096000000005BA
022_000000000003F386
188_7FEF7C2B80234308
023_000000547FC303EB
020_0040551000000E77
024_0000000020000E9C
080_23C23CC025200ED8
174_F07F0050BF6A0088
178_F27F00002F6B0017
0_
"Vin = <deleted>"
"DTC = 10115805100728100C68100D28D00C28513428000000 10115805100728100C68100D28D00C28513428000000"
"FCCA9193"
<deleted>
0120
037F2022
service date : 250505
0120
037F2022
0120
037F2022
Post
by jpl250rs » Mon May 05, 2025 8:11 pm
OIL0_DES1 while I requested OIL1_DES0 only help me to debug
but people tick anything so i consider to remove this choice for next releases
did you press the 2 button , or just the annual button ?
schmutzlutz
Post
by schmutzlutz » Mon May 05, 2025 9:04 pm
I tried both buttons "Service Interval" and "Annual Service"
Post
by jpl250rs » Tue May 06, 2025 4:49 pm
i don't undestand why you can't delete is then
in the log i see only one button , it's why i asked
schmutzlutz
Post
by schmutzlutz » Tue May 06, 2025 5:03 pm
Ok, too bad.
Do you have any idea what I could do to make it work?
Could it be a Problem that there is an active dtc from exhaust valve?
schmutzlutz on Tue May 06, 2025 5:04 pm, edited 1 time in total.
