Hi so I have a MTS 1200 2015 model. I have tried two different Devices ELM 327 & ODBII both I was told would work with my bike, but neither get all data, software is able to fetch only the VIN number and not any info about Ecu, software-hardware etc.
Can you help, I have repot from Methodist if the helps below?
"File generated On 04/08/2025 19:10:49"
"Software version 2.0.1.5"
"User Bike = 2015"
"Ecu = no ecu data"
"Softw = 10SW041870"
024_0000000000000BC5
080_18D0000030000B62
100_C70603503C000B90
022_000000000003F4D5
023_000000FC7F3304B9
188_7FE77D4B809744C0
110_21095A0440000E00
018_0002A0008200428E
019_96096000000002E9
174_1C8000004C6B0A01
178_1480022F767A0AFA
17C_00000000BF950AAA
020_0000950000004758
300_3698000034334E3F
"Vin = ZDMAA00AAGB007205"
"E03C6979"
0 : 031a8f03
1 : 10145A8F035A444D
2 : 2141413030414147
3 : 2242303037323035
4 :
5 : >
0 : 021A88
1 : 037F1A1255555555
2 :
3 : >
0 : 021a93
2 :
3 : >
0 : 021a95
1 : 100C5A9531305357
2 : 2130343138373055
3 :
4 : >
MTS 2015 1200 License issue
Re: MTS 2015 1200 License issue
it doesn't look so bad .
despite it's a elm v1.5 it looks ok , you can try to register
Still not working keep getting with both ODBII I’ve used.
Is there away to send license by email? Or can I copy and paste report from file into license data window?
Be sure you are using the right software and the rights cables for connecting to your bike , data are incomplete!
no you can paste the report in the licence form.
that is not formatted for the db
but you can paste the complete registration url here , i'll test it on my side
