Hi so I have a MTS 1200 2015 model. I have tried two different Devices ELM 327 & ODBII both I was told would work with my bike, but neither get all data, software is able to fetch only the VIN number and not any info about Ecu, software-hardware etc.
Can you help, I have repot from Methodist if the helps below?
"File generated On 04/08/2025 19:10:49"
"Software version 2.0.1.5"
"User Bike = 2015"
"Ecu = no ecu data"
"Softw = 10SW041870"
024_0000000000000BC5
080_18D0000030000B62
100_C70603503C000B90
022_000000000003F4D5
023_000000FC7F3304B9
188_7FE77D4B809744C0
110_21095A0440000E00
018_0002A0008200428E
019_96096000000002E9
174_1C8000004C6B0A01
178_1480022F767A0AFA
17C_00000000BF950AAA
020_0000950000004758
300_3698000034334E3F
"Vin = ZDMAA00AAGB007205"
"E03C6979"
0 : 031a8f03
1 : 10145A8F035A444D
2 : 2141413030414147
3 : 2242303037323035
4 :
5 : >
0 : 021A88
1 : 037F1A1255555555
2 :
3 : >
0 : 021a93
2 :
3 : >
0 : 021a95
1 : 100C5A9531305357
2 : 2130343138373055
3 :
4 : >
MTS 2015 1200 License issue
Re: MTS 2015 1200 License issue
it doesn't look so bad .
despite it's a elm v1.5 it looks ok , you can try to register
Still not working keep getting with both ODBII I’ve used.
Is there away to send license by email? Or can I copy and paste report from file into license data window?
Be sure you are using the right software and the rights cables for connecting to your bike , data are incomplete!
no you can't paste the report in the licence form.
that is not formatted for the db
but you can paste the complete registration url here , i'll test it on my side
These are both pre submitting and after when I get the above data issue
https://jpdiag.akress.com/traitement.php?UID=E03C6979
https://jpdiag.akress.com/jpdiag.php?Li ... D=E03C6979
ok you can use the 2nd one and add no bike data to the 1st line without pressing enter
you have this :
then it become this
don't forget to put the bike / year and your email
you have this :
then it become this
That worked thank you, just need to try it out. Will let you know if did the job.
So license worked thank you, but the service light does not go out go out when I reset it. Not sure where to go from here!
