2023 Ducati DesertX Cannot Reset Annual Service Indicator
Brian777
Post by Brian777 »
Hello. I am able to connect to the bike. I was able to read ECUs (on DTC page). When I click the Annual Service Buttons or service date buttons, all I get is an audible error message. No pop up, no dialog box. Should I be able to reset the annual service/date? Thank you so much!
I am using this device purchased from Amazon:
ELM327 OBD2 USB Adapter for Windows, ELMconfig Scanner with MS CAN/HS CAN Switch for Scan F150 F250 Car and Light Truck Check Engine Light, Diagnosis on Windows with V1.5 Chip
https://a.co/d/eWQhHw5
This is my file info (MelcoDiag.exe.debug):
"File generated On 11/11/2025 1:42:23 AM"
"Auto Detect Bike = Ducati Scrambler Desert X 2023"
"User Bike = 2023 Ducati DesertX"
"Ecu = UUUU"
"Hardw = UUU"
" vin 145A8F035A444D58414E4454385042303035393136
024_0000000000200162
080_2502BCC0002001DA
100_C71400000000113A
018_0002A00081004676
174_0C8000511F6B06FC
019_960960000000069D
022_000000000003F849
178_F47F04358C690667
023_000000547F6F08EF
17C_0080010071800680
188_8013802380BB481B
18C_7FEB80010000090D
120_6202845B1C400074
124_C8000000530000
"Vin = ZDMXANDT8PB005916"
"51B9DA25"
ZDMXANDT8PB005916
Re: 2023 Ducati DesertX Cannot Reset Annual Service Indicator
you need to register then the button will be activated
viewtopic.php?t=5
Brian777
Post by Brian777 »
Thank you for the response JP. I did register before attempting to reset and posting here. When connected and using the program the license button does not show anymore because I have the license and it is in the proper directory. The buttons are grey but they have a blue outline and I can click them. However I get the error tone.
Please let me know if I have misunderstood. What actions should I take next?
Here is a screenshot of the email with the license and showing it is in the directory.
c'est bon dans ta capture d'ecran mais pourquoi tu as
"lic not found"
ca veut dire le fichier cle.lic n'ertait pas là quand tu as fait ce rapport ou que le logiciel ne peut pas le voir .
Brian777
Post by Brian777 »
Thank you again for the response. My apologies, I copied my original file that I sent for the license request. A new file is below from connecting to the bike. It shows "registered"
What else can be done or attempted? What can I do? The buttons change color to light grey when I roll over them, apparently I can click them but after a few seconds I just get an error sound. No dialog box or error message.
Here is a 45 second screen recording of what happens:
https://drive.proton.me/urls/C85C6R396W#xPkrYSbqqHjf
(Proton Drive [cloud])
https://1drv.ms/v/c/f3effd04f3f31a5b/ES ... w?e=VZEmKz
(file in Microsoft OneDrive, seem to only work in Microsoft browser)
"File generated On 11/11/2025 2:35:54 PM"
"Ecu = UUUU"
"Hardw = UUU"
020_0040931000000FB7
024_0000000000200897
080_2502BCC00020082F
100_C7140000000018CF
174_10800054566B0C1C
178_028008339A690C70
17C_FE7F010089800C77
188_8013801F80BB4FF5
022_000000000003FF1A
18C_80038001000000DF
023_000000547F630FCB
018_0002A00081004DB9
019_9609600000000D52
"51B9DA25"
ZDMXANDT8PB005916
it's not an error beep , it's just a beep i put once the process is done .
desert X is one of difficult bikes to reset , when i check the post i don't find any successfull resets
Brian777
Post by Brian777 »
Ok. Thank you for reviewing and the reply. Sounds like it would require further development and research then.
yes and i see there is several electronics depends on the year , it' makes thing not easy
bleng
Post by bleng »
I have just had the same problem - same exact screens and 'Bing' but the service light is staying on.
Any further info?
This is on a 2016 X Diavel S.
I've edited this post to add the report info for reference.. as you can see I did try to reset the service and service date a few times. I am new to this software trying to help a friend who owns the bike, so there is definitely a chance I am doing something wrong but I have done this sort of thing successfully on my Triumphs. Anyway here is the report:
"File generated On 20/11/2025 22:15:37"
"Auto Detect Bike = Xdiavel S 2016"
"User Bike = XDiavel S 2016"
"Ecu = UUUU"
"Hardw = UUU"
" vin 145A8F035A444D4741303041414742303033323438
174_068000009C6B039D
178_EA7F0B264C9603B4
17C_000000000F850303
024_0001000000000438
080_18E2BC00102004E2
100_C7120330320004ED
018_0002A00020004714
019_9609600000030754
020_0000301000000474
230_008010000000027E
360_B00F0E2011250000
188_7FF77D1F80634B5F
022_000000000003FB6E
023_000000007F6B0B1
"Vin = ZDMGA00AAGB003248"
"A865ACF6"
ZDMGA00AAGB003248
037F1A2200000000
service date : 251120
021001
0250010000000000
***reset***
ZDMGA00AAGB003248
021001
0250010000000000
***reset***
021001
0250010000000000
***reset***
ZDMGA00AAGB003248
021001
0250010000000000
***reset***
021001
0250010000000000
***reset***
021001
0250010000000000
***reset***
Rene0031
Post by Rene0031 »
I have the same problem, with my 2023 Ducati Desert X
Thanks to this forum and good videos i got all lined up well, license in place all good bud i can not reset my 2023 desert X , it gives a bleep sound bud no change
Is there a other method now? or a trick to bypass it?
Thanks Rene
"File generated On 29-12-2025 11:04:44"
"Auto Detect Bike = Desert X 2023"
"User Bike = 2023"
"Ecu = 286.4.334.1CUUUUU"
"Softw = 10SW093339U"
" vin 145A8F035A444D3158303041415042303032313438
vin 0E5A883238362E342E3333342E3143555555555555
vin 7F1A1255555555
vin 0C5A953130535730393333333955
188_800B801F80AF479A
022_000000000003F7F2
18C_800B80010000083D
023_000000547F730797
020_0040B510000045D6
080_23F2BCC0002001C5
100_C7120000000011B3
174_14800000436B0F3C
178_0380082860690F8E
17C_0000000024800F4E
018_0002A000A20046CA
"Vin = ZDM1X00AAPB002148"
"7AF8D415"
ZDM1X00AAPB002148
0120
037F201100000000
0120
037F201100000000
0120
037F201100000000
