How to register
How to register
If resets buttons are greyed , it means the software is not correctly registered .
how to register :
1 - Ensure that the software can establish a connection with the bike.
If the sofware cannot pull informations , it may means the cable you are using are not well configurated and not suitable for your bike.
The process registration cannot work without pulling data from the bike.
2 - Once the data are pulled on the software , press get licence button ( the blue one ).
your computer shall be connected to internet, it will open the registration page .
If your computer is not connected to internet , after pressing the get liccence button , the registration link will be paste in your clipboard.
simply get connected to internet and paste the registration link in your browser to follow the registration process
3- Complete the form to receive the licence.
- the email where to send the licence file
- the bike details ex : monter 1200s 2018
- no others data shall be entered , do not alter the prefilled part
you will receive a cle.lic file quickly
4 - Install the cle.lic file into your application forlder ( melcodiag or jpdiag)
do not paste a shortcut , neither rename the file . Fhe name shall be cle.lic . cle(1).lic wont works.
5 - Restart the application connected to the bike , the reset buttons shall be enabled.
What to do if this is still not working :
- ensure cle.lic is present and not renamed .
- if you put the application in a a directory not beloging to your home folder , windows will restrict the file permissions .
you will have to access cle.lic properties and tick unlock file.
- in case you having a bike not poping the SN , genallry MTS2010 to 2012 , ensure to register the app with the PC you will use for the diag , else that wont works
recent example of not right registration:
bike : DUC4630800 => i don't know this model
serial : 7F9FCë => should be between 9 and 10
bike : 5291xt => i don't know this bike
bike : multistrada 1200- scrambler 800- monster- hipermotard- v4 => WTF ???
Kyrayan
Re: How to register
Post by Kyrayan »
Hello. I connected ms4 with kkl409 and jpdiag. I copied it and wanted to send it to you to get a license, but I received a notification that it is not necessary and 59m can work without a license. Is it true?
Re: How to register
what is an MS4 ?
it's right that 59m ecu don't need to register
