TPS Resent on M1100
Bonda78
TPS Resent on M1100
Post by Bonda78 »
Hi all,
i'm a new worker with MelcoDiag and M3C9 and i want to rebuild my M1100 (after an accident last year).
In this moment i'm working on M1100 engine and i changed my throttle system (with other TPS) because i damaged the original throttle system.
This afternoon i saw with Melcodiag, the error below:
Errore Melcodiag.jpg (55.05 KiB) Viewed 5531 times
When i whatched it, I whatched the value and it is 15%(please see the yellow row):
Valore del TPS.jpg (94.34 KiB) Viewed 5531 times
well, i went with the reset TPS but, after i touched the relative button, i didn't see nothing. The TPS remain 15% and i still have the same error.
I remake the sequence and after i close the MelcoDiag but nothing. when i restart the engine, nothing. The same value and error.
I made the same thing with M3C9 program but i have the same result.
Can we help me? do i make some errors?
Thanks guys,
Luca
Re: TPS Resent on M1100
none of the tps fields are working in relation of your throttle position ?
you shall click on the field after scrolling it , to make it blue to be taked into account too
Bonda78
Post by Bonda78 »
When i selected the field TPS (please see the last image) i read 15% when the throttle are in minimum position. If i remain in this field and i rotate the throttle i see an increase of value. i arrived around 117% (It was the end of throttle rotation)..
After this description I hope to describe that your program work well but the TPS remain at the 15% at minimum position forever also after make the TPS reset with your button in Melcodiag..
I make a mistake during the TPS process?
just to confirm i'd click into the TPS field to make it blue
Anyway the process looks ok , it would be good to see the angle value , it shall be arround 85% with full throttle
Bonda78
Post by Bonda78 »
Ok, in the next week I will make your test and i Will be come Blue the field of TPS in your program.
I Will male the test of % in full throttle because i didn't see 85% but much more value (of i Remember well around 117%).
sorry i mean 85° as angle value for full trottle
Bonda78
Post by Bonda78 »
i tried to test in this week.
I control the % in the full throttle position. I saw the value 100% (when i arrived in this position i saw that i had another small part of gas wire but the throttle doesn't misure this extra lenght).
After i tested the reset TPS, higlighted in blues the field TPS. I touched the button "Reset TPS" and after i controlled in the correct field but it remain at the value 15%.
I disconnect and reconnect but the value didn't change.
Another test i tried to press the other two buttons. In sequence "SELF ADAPTIVE A/F" and after "TPS Reset Closed" (in the mean time i saw an OK over green square in the right angle below the window of program). immediatly i controlled in the main menù the TPS and i saw the 15% of value (it remain the same).
I did some mistake? what's the problem that i don't correct the value?
Thanks,
Luca
P.S. I made a video but in the forum i can't share it because it very small the size to attachment.
