Monster 1100S issues – Melcodiag no reset functions
Sky_Walker
Post by Sky_Walker »
Hi everyone,
I’m looking for some help with my bike:
Ducati Monster 1100S using Melcodiag
OBD2 Diagnostic Scanner used:
https://www.amazon.com/PARANNIC-Diagnos ... B08887TNBB
I’ve managed to get a connection to the ECU, and the software reads the ecu data and i was able to get the license.
However, I cannot reset the desmo service warning. or perform a TPS reset. All buttons on Melcodiag do nothing at the moment.
From what I’ve seen, other users with similar setups are able to perform these functions, so I’m trying to understand what I might be missing.
Any guidance would be appreciated.
Thanks!
My debug file:
"User Bike = Monster 1100s 2009"
"Ecu = S180040101"
"Hardw = QD084010"
"Softw = 84IU1MIL"
" vin:100E5A8C3239353221353735313620202220AAAAAAAAAAAA
8 PIDS active founds
080_0000000000000000
081_01000000C8000000
010_C800000000000000
100_0000000000200000
211_37820037D4000047
280_20204D4F4E535445
290_5220313130302030
201_0000000000000000
"Vin = 295257516 "
"38AD6C6B"
295257516hard :QD084010
soft :84IU1MIL
NO DATA
NO DATA
Re: Monster 1100S issues – Melcodiag no reset functions
there is something wrong with the licence "not registered"
have you done all step after the chapter 5 here viewtopic.php?t=5 ?
Sky_Walker
Hi, thanks for your reply.
I followed all the steps you suggested.
Running Melcodiag from a dedicated folder on C
License file is placed in the same folder. Debug shows “lic found”.
Windows Defender disabled.
Running as administrator.
Despite all this, i get "not registered" on the debug file and the TPS reset and service reset buttons remain greyed out.
Thanks again for your help!
Ok there is some progress then
The serial is well read when you enable m3c option ?
Sky_Walker
Thanks for your reply. Unfortunately, there is still no progress.
The ECU is read correctly and the license file is present. The debug file shows:
"File generated On 3/23/2026 7:56:12 PM"
"Ecu = S180040101"
"Hardw = QD084010"
"Softw = 84IU1MIL"
211_438A003DD4000045
020_0000064FA1000000
028_0000000000000000
280_2
"Vin = 295257516 "
"38AD6C6B"
soft :84IU1MIL
I have followed all the steps carefully, but the reset buttons remain greyed out.
Any further guidance would be appreciated.
Thanks.
i resent one
Sky_Walker
Just a quick update — I finally got everything working.
jpl250rs kindly provided me with a new license file, and after that everything worked perfectly.
I was able to reset the TPS and clear the Desmo service without any problems.
Diagnostic tool used:
Thanks for the support and guidance.
